Realflight
I got a realflight sim from a guy and I cant anything to work. Im not sure if I have the right discs or not. The ones I have are lebeled as Add-Ons. I cant get past the stage where you are asked to enter the number and then I cant go any farther....Any suggestions?..................John
It seems you have aquired the add on disks only. You have to first have the RealFlight G2 Simulator installation disk before you can use any of the "Add On" disks. The add on disks simply extend the range of options you have as far as planes, airports , etc.
Aight....... I got my mess runnnin but now my rudder wont work. I tried to adjust it on the control adjustments but the rudder is stuck in one position. I mean the stick moves all around but I get no response on the puter. Could it be that the pot or whatever its called in the transmitter is bad? If so can it be found at Radio Shack. Has anybody else had this problem?
Try here for a lead www.rc-electronics.co.uk they should be able to help
Dont know about ur first ? sry.
