Fsone elevator problem
IL
Just purchased Fsone,Having problem getting elevator control to work. Exchanged unit still won't work. Anyone have any clue to the problem. All other controls work.
Hi,
You probably didn't calibrate the transmitter.
If you just got it there's a few things you should check that you have everything setup right.
For starters go to the FS One website and download the latest upgrade. Also make sure you have the latest audio driver installed on your computer.
Even if you don't do or need to do theabove, then once in the program, you should calibrate the transmitter before you go fly. You calibrate it by going to the transmitter selection and just clickon calibrate for the one you have. Keep clicking next until you get out and then you're done.
Dave
Dave
