RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
simulators
Old 12-12-2008 | 04:23 AM
Default simulators
Which simulator software is best to choose and what are the hardware specification required to run it?
Old 12-12-2008 | 09:34 AM
My Feedback: (31)
Default RE: simulators
do u already have a computer to run it on if so send the specs:
Old 12-29-2008 | 12:39 PM
I recieved a E-Sky EK2-0905A flight simulator and a F15E RC airplane fo Christmas. Since I have absolutely no experience I need to use the simulator alot. The problem I have is that the simulator I have gives me absolutely no instructions as to what the various knobs and sticks control. There is a vidio on the setup dvd but everthing is in Chinese. I don't seem to be able to figure them out on my own as all I am doing will not get the plane off the ground. I can guide it down the runway but can't get off ground no matter what I do. Can someone please help me understand what the different controls do??
Harry Boher
Old 03-15-2009 | 01:32 PM
ok so i just saw a video of that sim from hrboher and its basically fms with the e-sky name on it.. is the sim in english? can u see the controls tab on the menu? if u can click on analog control then mapping/calibration and set it up from there
Old 03-15-2009 | 01:59 PM
I have a G4.e flight simultor I purchasd from Towerhobbies.com. It is an awesome simulator. They have many different software progrms for this simultor. It is rather pricy but you get what you pay for which I found out the hard way. I have had other flight simulators, but I must say this is the best of all I have had. I suggest you go to towerhobbies.com and check them out. I am relatively new to RC planes and helicopters and this G4.5 has really helped me. I hope this info may be of help
Old 03-15-2009 | 02:03 PM
Tinitybrown, I just sent you a relpy and after reading it I see a typo. I typed G4e simulator and it should have been G4.5
Old 03-15-2009 | 03:26 PM
ORIGINAL: hrboher
Look at the upper right hand corner of the post with the typo in it. See the "edit" button? Click it and you can edit the post to fix the typo.
Old 03-15-2009 | 03:40 PM
Thanks for the info. I wasn't aware you could edit after posting, so thank you again.
