Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 HELP!!! FSone 2.4 SETUP >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 07-20-2009 | 12:03 AM
Default HELP!!! FSone 2.4 SETUP
Hi i have had hanger 9's FSone for some time now
i had it running well on futaba's 8U but once i upgraded to 2.4 it does not seem to sence any of the control inputs
i am using a new Futaba 10C with integrated 2.4
i would love any help or ideas
corey
Old 07-20-2009 | 01:00 AM
MSelig's Avatar
Default RE: HELP!!! FSone 2.4 SETUP
Is your Futaba Tx in PPM mode?
Old 07-20-2009 | 12:16 PM
I can not set it to ppm mode becuse this is the newer 10c without the removable module.
Old 07-20-2009 | 07:23 PM
MSelig's Avatar
Are you sure that you cannot set it to output PPM on the trainer port? That would make it incompatible w/ *all* simulators! The Futaba manual "10CAP/10CHP/10CP" makes all sorts of references to PPM.
Old 07-21-2009 | 12:38 PM
Thanks i just looked through the whole manule agin i found the triner function wich activates the ppm mode
but also im not using the transmiters that you listed i have the 10CAG
thanks though
Old 04-26-2010 | 04:48 PM
Are you using the HANS3030 adapter for your 10C?
http://www.horizonhobby.com/Products...rodID=HANS3030
