Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Futaba 6ex2.4 compatible to simulators? >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 08-03-2009 | 02:00 PM
Default Futaba 6ex2.4 compatible to simulators?
Hi
Any real experience with this transmitter? It seems most simulators USB interfaces operates only with PPM output signal and 6EX2.4
don´t provide this signal mode. Any clue?
Thanks.
JC
Old 08-12-2009 | 06:20 PM
Default RE: Futaba 6ex2.4 compatible to simulators?
I would assume that the trainer cable will give standard digital signal
You can buy a Futaba Trainer Box that will work with Futaba FM,PCM and 2.4GHz "One universal Trainer box"
FM,PCM,2.4GHz is the TX>RX output/input signal "not the digital signal that is used internal in the radio "
You mention that the PPM signal is used trough USB that sounds right
Regards
la8pv
Old 08-14-2009 | 09:23 PM
Banned
I have a 6ex and an ebay cable. It works fine. You can get the canle on ebay for under $10. Remeber to request the Futaba square connector.
