Aerofly pro and Win 7
My Feedback: (39)
FL
Cannot get the system to calibrate. Indicator bars are all over the place. Any suggestions?
Updatejust loaded the program on my wifes laptop with XP. Same thing. So I have switched computers, and radios (a JR and a Futaba) with same results. I had sent the USB interphase card in to tech support, and they returned it saying it worked fine for them. Only thing left is software and cable. Any ideas guys?
CA
you might need to remove aerofly completely,,,remove it from all programs,,,then click on drive c ,,,open program files find ipacs and delete the ipacs folder,,, restart your computer,,,and reload the program,,,then go to aerofly pro dluxe website and download the appropriate patch,,for whatever version youre using,,im not an expert ,,but any ghost images or remmanants of any old or corrupted files will cause a conflict ,,in some manner such as display or running the program or individual components of the program ,,like calibration,,,lastly make darn sure you have the correct adaptor,,some only will respond to a stereo or mono style plug,,even if the program senses the dongle or transmitter....
CA
ps,,also click on areofly icon and see if you need to check compatibility,, you may have to change your settings back to win xp sp 2 or 3 ,,,,also if you have installed a clean install of win 7 over xp you will find a file with old xp programs ,,you will find your old aerofly setup there,,,you can drag up flyrun to your desktop and run the old setup,,,but its better to delete that folder,,,because it will prevent a fresh areofly reload from working ..
