Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 FSone with Windows 7 >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 08-16-2010 | 03:23 PM
cessna20's Avatar
Default FSone with Windows 7
Guys!
Please let me know does FSone work with Windows 7.
I have installed today, but nothing launched.
Maybe exist special patch for that?
Please advise. I don't like install second Windows XP for this simulator.
Old 08-16-2010 | 11:09 PM
Banned
Default RE: FSone with Windows 7
Get XP or run virtual XP. Win7 is junk.
Old 08-17-2010 | 02:57 PM
MSelig's Avatar
ORIGINAL: cessna20
Guys!
Try updating your graphics card drivers. That should solve it. FSOne runs on Windows 7, so that's not related to the problem.
You don't need a FS One patch to run it, but you should install the latest patch that you can download from the FSOne website.
Michael
Old 08-24-2010 | 12:40 PM
opjose's Avatar
ORIGINAL: cessna20
Guys!
First when you run the FSOne setup, don't use "autoplay", instead find the setup.exe file on the CD and right click then select "Run as administrator"... or you could temporarily disable the UAC and then reboot and then install.
Once installed you MUST run FSOne as the Administrator at least once to let it set up the configuration files.
If you still have problems run it in XP Compatibility mode.
It works fine in Windows 7 if you do the above.
Old 11-16-2010 | 07:54 PM
qwertypemdas's Avatar
I have installed fsone on my win7 laptop with no problems except i had to delete the patch files from the update folder after they installed otherwise it would try to reinstall the patches on startup. Runs great for me.
Old 11-17-2010 | 03:14 AM
I had the same problem with with Windows 7...........................Updating my video drivers corrected the problem. Can somebody tell me where I can obtain the sim cord that goes from a newer Futaba Xmitter to the USB interface?
