RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Smoke with Real Flight G2 (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1420121-smoke-real-flight-g2.html)
Kirk Brimmer 01-11-2004 06:40 AM
I'm having trouble getting smoke to work on some of the models, i.e. the F-16. Anybody got a step by step foolproof way to set up smoke on any airplane? I'd like it to work via the 3-position switch.
GarySS 01-11-2004 06:22 PM
RE: Smoke with Real Flight G2
I have not been able to get smoke with any "jet" engined model, even when using a ducted fan set up. Has anyone else??
jbeck 01-12-2004 06:09 AM
I am pretty sure that Real Flight uses only Switch 2 for smoke - I am not sure if you can set that up differently, but I'm pretty sure that you can not...
Also, I don't believe that all planes offer smoke capabilities. When selecting an aircraft, if you read the description, it will usually mention something about using smoke on switch 2. I don't use it that often, so I only remember seeing it on a some of the aircraft.
Generally speaking, I had trouble getting smoke to work at all, on any plane. Eventually, I searched the knowledge base and found a suggestion to delete the RealFlight.ini file. Once I did that, and started it up again, it worked fine.
Grumpy Monkey 01-12-2004 06:20 PM
1 Attachment(s)
If smoke is not an option on the original plane, you can make a copy. Edit the copy and go into misc tab, click the box that say radio controls smoke, go back to the servos tab and pick a switch to use it on. It will work with combustable engines and ducted fan but not turbne. Here is a Large b-17 blowin smoke and an a-10 with a DF smokin up the place. Hope that helps,
Warren
Grumpy Monkey 01-15-2004 10:08 PM
1 Attachment(s)
LOL, You can also set up a cap with retracts. Pretty funny
Warren
Kyle300S 01-15-2004 11:29 PM
or without editing the model you can just hit the Tab key on the keyboard and you will get smoke. sorry it will not work with turbines, but will work with a ducted fan.
Kyle
Flying Foot Doc 02-04-2004 08:58 PM
I have Blue smoke set up with the Left aileron. It goes with the Orange exhaust...Go Gators! (I'm a Gator Pop!!) Andy
