RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   AFP controller help!!! (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1850138-afp-controller-help.html)
GRANT ED 05-27-2004 08:06 AM
I just bought AFP and have tried to run it with little success. Problem being when I load the game it says it can't find the controller. I have tried the controller in both ports and have set it as as per the manual.
Please help. What do I need to do?
STLPilot 05-27-2004 08:17 AM
RE: AFP controller help!!!
Install the latest AFP udate patch, front page of www.aeroflypro.com
Give that a try.
GRANT ED 05-27-2004 06:57 PM
Thanks STLpilot I will give that a try tonight.
GRANT ED 05-28-2004 04:27 AM
Tried the patch and it still don't work. I am using Windows XP. Can someone help PPPLLLLLEEEEEEAAAAASSSSSEEEEE
rajul 05-28-2004 06:00 AM
Ed, did you plug in the 9-pin serial interface cable into a free serial port (COM port) as well? it is always required even if you use the game commander. The other end of the serial interface cable is a stereo jack. Just leave it alone. You could plug this into your own Tx with the proper adapter if you choose to use your Tx instead of the game commander later.
Additionally, pls ensure that there are no other programs running in the background. Cheers !
GRANT ED 05-29-2004 02:26 AM
:D You the man Rajul. That was the problem :D
Now, I tried to fly the raptor and it would just get off the ground at full throttle, the planes also seam to be not getting full power. I tried adjusting the travel but it didn't seam to make any difference.
Any idea's??
rajul 05-29-2004 02:33 AM
I believe it's your simulation speed. In the flying mode, go to file---->general option------>simulation speed. Increase that speed to what you're comfortable with depending on your skill level. Let me know how that works for you.
STLPilot 05-29-2004 08:49 AM
Also make sure when you calibrate you leave your sticks in neutral before you calibrate. Then when you calibrate make sure you see full movement on the red bars.
GRANT ED 05-30-2004 02:26 AM
Thanks guys. I am experienced in flying so I have it set to 100% speed.
When I did the calibration the red bars don't go all the way to the end. Can I adjust this?
rajul 05-30-2004 02:39 AM
Ed, you can adjust your throws in the controls menu. Which Tx do you have ? Why not try using your own Tx instead of the game controller, especially if you have a computer radio ?
GRANT ED 05-30-2004 03:22 AM
Thanks Rajul. I have got it working correctly. I have a PCM 9X which I will use but just for now I wanted to get the normal controller working.
rajul 05-30-2004 03:25 AM
Looks like you've got a great combo . Enjoy !
