RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   Fms Cable Interference ! (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/1879805-fms-cable-interference.html)
chrispaiva 06-07-2004 07:50 AM
Hy Guys,
I'd like to see if somebody could help me with one issue.
I've recently created a FMS cable using the instructions of this site (http://www.heliguy.com/nexus/fmsinterface.html). Something really weird is happening.
I am using a WinXP and I installed the PPJoy how they recommend. After I turn my radio(TX) on, one noise starts. it is like a interference between the radio(TX) and my computer built-in speakers.
Has anybody experienced anythink like this and what you did in order to solve the problem ?
I would appreciate one help.
Christian
(Brazil)
rajul 06-07-2004 07:57 AM
RE: Fms Cable Interference !
Chris, this fms interface is a basic one and can be glitchy especially if you are using an unshielded cable. Try using cat 5 computer data cable which has ground shield to minimise emf interference.
chrispaiva 06-07-2004 08:21 AM
Rajul (?)
Thanks for you reply. See I am using a Avaya Cat6 cable and I don't know why I am having this problem.
What would you recommend ? Try another cable or try another kind of interface ? Works fine this one but with some noise in my ears. :-)
rajul 06-07-2004 08:33 AM
Check for dry solder joints and poor connector joints. That could also cause glitching.
chrispaiva 06-07-2004 12:21 PM
I did it twice :-( .... First time I thought I could made a mistake, because of the noise, then I decided to rebuild the cable. :-)
Is this noise normal ? I am thinking and buy another cable like that ones used in speakers.
Eric Brouwer 06-08-2004 07:28 AM
I do not have a picture to show, but try the following:
Go to "Parallel Port Joysticks" under "Control Panel".
Click on "LPT1" under "Configured Joysticks"
Click on "Options"
Ensure all "Runtime Debug Options" are cleared (not ticked)
As far as I can remember, this debug option will give out a beep via your speakers when there is a signal present.
chrispaiva 06-08-2004 08:48 PM
1 Attachment(s)
Great Eric,
It has worked perfectly :-))))
I did some tests.. FMS can handle the signals very well but I cannot say the same with Real Flight G2. G2 doesn not detect the signal of the acelerator. This is the only problem I got. Did anybody try to use this kind o cable with G2 ? Will it work or G2 is more exigent than FMS ?
Thanks to everybody for replying my questions..
Ps.: Take a look on the attached picture. The channel 3 has no description.
Regards
Christian
Brazil
Eric Brouwer 06-09-2004 02:39 AM
One thing you can try, is to assign the throttle to analog channel 5 in the PPJoy setup. I remember something about this when I was playing around with the PPJoy software. I am not 100% sure, but I think this problem was only present when using Win98.
phildc 06-30-2004 07:36 AM
FMS Transmitter PC cable
Link to the (simple)PCM project where you find a PIC cable working in XP and 2K,
a number of freeware softwares for transmitter setup, flight recording, a.s.o.
Also a soft to apply trim and expo to a normal game joystick. This makes great
difference in FMS.
See 'Articles' about '(simple)PCM' and 'joystick' at
[link]http://www.jdm-nivelles.be[/link]
Also our Air show on Aug.22, 2004 30km south of Brussels, near E19.
Come and see us, you can win a 950 Euro RC plane +radio+equip
