Networking with G2
Does anybody else have trouble with being a host on G2
I set up a host situation, and my friends still don't seem to be able to log on. Any details setup pecuilarities that I might not know about?? I'm able to log on to some of the others, but my search engine doesn't seem to work very well. DO YOU NEED TO PUT A PORT NUMBER IN FOR IT TO WORK? DO you always use the default no 6073? Frank |
RE: Networking with G2
Are you running a Firewall?
(ZoneAlarm,BlackIce,Linksys Router, and ect.) If so you need to open ports 6073 and 2300 to 2400 and direct them to the box that is hosting. I allways use default port. If you use a differant port then others will not be able to connect, unless they know your IP and port. |
I don't know if I'm running a firewall, but not to my knowledge.
How do you tell/find out? |
| All times are GMT -8. The time now is 04:49 PM. |
