new usb controller smoke feature
i see that the new controler has a smoke toggle on the right. i just plugged mine in and starting playing, anyway how does that smoke button work (does it require set up) as i usually just turn it on on the on screen menu. So will i be able to cut it off and on from the controller?
I was wondering the same thing. I am sure somebody can help!
yeah i suppose i will have to find out the answer and get back with you. if you want a stong standing in post, your subject line really should read:
Jr vs Hitech 3wvs DA JR vs Futaba you get the idea...... I will do some reseaching and will find out the deal talk with you soon gerald PS we may get lucky and have Ms. A. Cross provide us with the answer as i see quite a bit......... |
lol!
Mama said if you won't something done?
1 Attachment(s)
Mayur,
Check this out go to the P-51 plane its set up with more channels, anyway change your setting to read like the pic i included the main thing is change smoke to read channel 7. With this you can now use smoke on that plane. Now that 330 is another deal i am working on. Let me know if this part works for you. ? ???What was that mama use to say it's on the tip of my toungue.......LOL |
TME pump on 40oz.......
1 Attachment(s)
Okay i have it go to the edit menu under planes make sure you have a plane renamed for this use.
then go under miscellaneous: then look at the bottom of the page wow it says let the radio control smoke of course click on that. make sure under the servo menu you have smoke controlled on channel 7. Wow we are smoking now TME pump and all. I hear that it makes a mess to clean up on the plane well i am getting ready to find out............. |
if all else fails
1 Attachment(s)
make sure under edit radio type software radio is checked then also go to edit Now!
make sure under channel 7 your numbers read -100 to 100 on channel 7 when you stroll down to that part i have included a pic i have all my plane able to smoke from a click of a toggle now. |
Thanks a lot for this info this has been driving me nuts for the past few days tying to get my own radio to work with the smoke.
Thanks Mike Badger |
Krayzc,
you are soo cool! :cool: thanks a ton, have fun, mayur |
I have the 9 CAP radio by Futaba , where can i get teh connector to connect my radio to the Computer .
The buddy connector in these 9 CAP radios are are of differnt size. |
i know one of these buttons will work!!!
1 Attachment(s)
you should be heading the right directions with this link:
http://www.rc-electronics.co.uk/index.htm if that is not what you are looking for you have to go the experts: http://www.gpsoftware.com/ http://www.realflight.com/# |
Originally posted by krayzc yeah i suppose i will have to find out the answer and get back with you. if you want a stong standing in post, your subject line really should read: Jr vs Hitech 3wvs DA JR vs Futaba you get the idea...... I will do some reseaching and will find out the deal talk with you soon gerald PS we may get lucky and have Ms. A. Cross provide us with the answer as i see quite a bit......... :confused: :stupid: |
oooohhh let me answer horshack sit down!
WRXlovr
what i was telling Mayur is no one was giving us the scoop on our being lost at how to make a smoking plane fly. I was saying it would be easier to get some replies if we were starting a debait type of question. You feel me? |
Re: oooohhh let me answer horshack sit down!
Originally posted by krayzc WRXlovr what i was telling Mayur is no one was giving us the scoop on our being lost at how to make a smoking plane fly. I was saying it would be easier to get some replies if we were starting a debait type of question. You feel me? |
| All times are GMT -8. The time now is 08:54 PM. |
