Installing new schemes - Preview
G2 Pros,
I am using G2 and I am quite happy. Also downloaded the Morrisknife (thanks Bill;) however, when I click on relaod, the new scheme won't show up in the preview. Is this normal or do I do something wrong here??? Regards Rainer |
rmm
Click the plane that its based off of. And then click
the arrow. then you will see the rest of the planes in that file. good luck Jeff |
You will also have to restart G2 if you were in it when you downloaded and installed the new scheme.
Thanks Mike Badger www.Aero3D.net |
No preview here either
I think you are asking about the little about 1" x 1" picture of the plane when selecting the aircraft? Mine only shows the original scheme/plane as well.
G2 picture 1" x 1"
Yes,
the small picture is what I was referring to. I guess it won't change - well not too bad. I just thought I must have done something wrong! Thanks for your advice! Regards Rainer |
I was confused like that when I downloaded the SIG Sukhoi scheme. It didn't show up until I reloaded the software.
Sorry, what do you mean by confused?
Does the new plane show up in the plane selection menue (the small 1" x 1") or not? Like GooberVA stated - it doesn't show in the preview, however, the plane loads ok. Rainer |
No the picture of the airplane will not change schemes its only there to show you what plane your choosing.
| All times are GMT -8. The time now is 05:17 AM. |
