Flapperon set-up
Is it possible to do mixing with the G2 Interlink controller ?
If so...could someone please tell me how to set this up, I would like to play around with flapperons on the Cap 232. Thanks Jason E Lepper :confused: |
Flapperon set-up
Make a copy of the Cap 232 and then edit it as follows:
In servos, set right aileron to channel 6 Then load the copied one in G2. Go to edit radio: On channel 1 : left aileron, check input 6 checkbox and enter from 100 to -100 and set when Switch 2 on On channel 6 : right aileron , check input 1 checkbox and enter -100 to 100 check input 6 checkbox and enter -100 to 100 and set when Switch 2 on You will now have flapperons/spoilerons controlled by the right hand switch and the turning knob thing Make sure your low rates and exponential are the same for Channel 1 and Channel 6 You can also mix in some elevator into channel 2 from input 6 when switch 2 is on if you like (say from -20 to 20 or something along those lines) |
| All times are GMT -8. The time now is 09:41 AM. |
