RCU Forums
-   RC Flight Simulator Software (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/)
-   -   BVM KingCat for AFPD? (https://www.rcuniverse.com/forum/rc-flight-simulator-software-138/3696193-bvm-kingcat-afpd.html)
Greg.B 01-10-2006 01:45 PM
RE: BVM KingCat for AFPD?
ORIGINAL: STLPilot
ORIGINAL: Greg.B
I'll have a crack at that if you like:D!
Well duh ....
Well I need the plane:eek::D!
TWRC 01-12-2006 01:21 AM
1 Attachment(s)
Hello All,
It's 1am and the King Cat is finished! I'll send the files to Dion after this post and with that hopefully the model will be available for download soon. Thanks for all your kind words, I hope you like this new model. A special thanks to Karl-Heinz (Rodeo) He helped me many times learning this stuff in the past:D
Time for bed:Dzzzzzzzzzzzzzzz
GoeKeli 01-12-2006 01:29 AM
That is incredible Pat! Thanks a million! Get some sleep!
JOE Kelley
Max1 01-12-2006 06:00 AM
TWRC thank you so much.........that is great work...........have a great week...Max1[8D]
Ian.W 01-12-2006 06:16 AM
just awesome[X(]
STLPilot 01-12-2006 07:49 AM
POSTED! THANKS PATRICK! Flies amazing.
Direct link for registered users: http://aeroflypro.com/ipw-web/bullet...hp?p=2040#2040
Link for non registered: http://www.aeroflypro.com/download (look in General Aviation)
HAVE FUN!
Greg.B 01-12-2006 09:25 AM
1 Attachment(s)
It's stunning[X(]:D thanks Pat!!!!:D
And we sort of have vectoring thrust tooooo:D! I've somehow got to move the ring onto the jet nozzle....any ideas?[sm=confused.gif]
BW!
Greg.
Greg.B 01-12-2006 11:33 AM
Here's a vid: [link=http://www.streamload.com/Deliver/Deliver.asp?cxInstID=15770324&nodeID=20523336&retu rnPage=http%3A%2F%2Fwww%2Estreamload%2Ecom%2FNodes %2FNode%2Easp%3FcxInstID%3D15770324%26nodeID%3D113 9463089%26alreadyCurrentTab%3Dtrue]KingCat Vectoring Thrust[/link]:D
Sorry about the choppy landing!
BW!
Greg.
TWRC 01-14-2006 12:38 PM
Very Cool Greg. Nice Video. The graphic issue is more than likely a conflict between the TMD and TMG files. Did you rename anything Jetcat in the TMD file? Becaue if you did the name jetcat is defined as a sub object of the fuselage so the location has not been defined. Another thing I thought of is if you tried to make the Jetcatobject graphically move in combination with the power source named Turbine you would have to redefine the object Jetcat as a main object in the TMG and create new lines in the TMD file for the Jetcat. I a only guessing on how you did what you did:D
Great Job
Pat
TWRC 01-14-2006 01:10 PM
Hey Greg, I looked at the Harpoon files and it’s now clear to how the thrust vectoring works.
cd JointRingThruster/
X = tmvector4r( 1.0000, 0.0000, 0.0000, 0 )
Y = tmvector4r( 0.0000, 1.0000, 0.0000, 0 )
Z = tmvector4r( 0.0000, 0.0000, 1.0000, 0 )
R = tmvector4r( -0.5558, 0.0000, 0.0433, 1 )
cd JointFuselageRing/
cd Ring/
X = tmvector4r( 1.0000, -0.0000, 0.0000, 0 )
Y = tmvector4r( 0.0000, 1.0000, -0.0000, 0 )
R = tmvector4r( -0.5565, 0.0004, 0.0433, 1 )
cd Thruster/
X = tmvector4r( 1.0000, 0.0000, -0.0000, 0 )
Y = tmvector4r( -0.0000, 1.0000, -0.0000, 0 )
On the “R” lines (-0.5565) need to be moved farther forward. I’ll be back with a ball park coordinate.
TWRC 01-14-2006 01:20 PM
(-0.5558) needs to be changed to (-0.4334) in order to locate the Ring just behind the Jetcat's nozzle:D
I recommend making a backup of your present TMD file before making changes to it. It would have saved me many problems in the past:D
let me know how it works for you.
Pat
Greg.B 01-14-2006 01:23 PM
Thanks very much Pat:D!
I'll tell you how it goes!:)
BW!
Greg.
Greg.B 01-14-2006 02:11 PM
Hi Pat,
I can't get it working[:o]!
Which values do I need to change?
I've changed the TMD to look like this:
R = tmvector4r( -0.4334, 0.0000, 0.0433, 1 )
cd Ring/
R = tmvector4r( -0.4334, 0.0004, 0.0433, 1 )
cd Thruster/
TWRC 01-14-2006 03:19 PM
That's odd...?????? your structure looks right. There must be something simple we are not seeing. May I have the TMD and TMG files to look at? [email protected]
What are the results your seeing? Did you modify the object File with a "ring" Object or is aerofly reading the object file from the Harpoon folder. Aerofly will do this if the specific aircraft folder dose not have the object defined in the TMD file aerofly will sometimes look elsewhere for if. I've seen this before, and then you could change the location lines in the Kingcat's TMD file but will make no difference because it's reading the Harpoon's TMD file. You could answer this question by temporarily removing the Harpoon form the aircraft folder and run the Kingcat. if you don't see the "Ring" graphic you know aerofly was reading the Harpoon files looking for the Object "Ring" and thus the TMD file that goes alone with it. It that case I can modify the .suf file and create a new Jetcat.obj file for the King Cat. I'm just throwing out possibilities but would need to see the TMD/TMG files to know for sure what exacly the problem is. I Know we can fix it:D
Pat
Greg.B 01-14-2006 03:33 PM
I'll send it over to you Pat it's the easiest way;)
BW!
Greg.
TWRC 01-14-2006 03:39 PM
I had another idea, In the future you could rename the .OBJ Jetcat to Ring in bother the OBJ and the TMG fils and then the whole turbine would move. That would eliminate the need to modify the .suf wire frame file. Just a idea:D
TWRC 01-14-2006 07:40 PM
1 Attachment(s)
:D:D
GoeKeli 01-15-2006 12:44 PM
Very nice job on this model! You did it. I just need to add more lag to the turbine spool up. The vector looks fun!
Anyone try a crow setting yet for landings? I'll try to get this model to fly as close to the real one for flight training.
Joe
STLPilot 01-15-2006 06:47 PM
How does one go ahead and get the 3D version??????
STLPilot 01-17-2006 01:28 AM
The new vector thrust model is online, right next to the other one.
diablo 2002 01-31-2006 01:01 PM
can anyone build a JR diablo 2000 please?
thanks
STLPilot 02-13-2006 07:07 AM
Get some 3 views of it and someone will do it. Lots of people around the world model for AFPD. Eventually everything asked for appears.
rainedave 02-13-2006 09:05 AM
TWRC, that is very impressive. I have been fooling around with Metasequoia also, but with less successful results: http://www.rcuniverse.com/forum/m_3857320/tm.htm
and: http://www.rcuniverse.com/forum/m_3887423/tm.htm
I have two questions, if you don't mind. One, how do you create round wingtips like the ones on your Stearman? Smooth wingtips have been the most challenging part for me to make so far (see my Kaos and Falcon above).
Second, does the newest free version now export .x files? I have been using 21a because 23b will not export working .x files.
Thanks, and great work.
TWRC 01-31-2007 11:57 PM
1 Attachment(s)
Rainedave,
sorry I didn't post sooner in response to your question. I didn't realize there were unread questions on this post. I attached some picture to help illustrate my methods to make round wing tips. The scale tool is wonderful:D
I'm using Version R2.3 LE(23b) and it only Exports as .SUF not .X files. You can Save files as .X and try to open it in another program but I've been unsuccessful using programs like Autocad 2000.
Timbba 04-29-2007 06:11 PM
I can't find this model anywhere... Could someone give me direct link to file or send it to my email??
