flaperons on G3
does anyone know if you can program something on the G3 interlink radio to where both ailerons move as flaperons by one of the switches?? The Yak54 harriers MUCH better with the ailerons up about 10 to 12%, but I can only figure out how to make them like that all the time. As you can guess, it doesnt fly well inverted when its set up like that:D
any help would be great! Thanks! |
RE: flaperons on G3
Try this:
http://h1.ripway.com/jaafit/RFG3/Flaperons.plnG3 Here's what I did. I changed the right aileron servo to get input from channel 9 instead of 1. Then I added inputs to channel 9 so that it mixed channels 1 and 8, 8 being the 3-pos switch. Then I added a channel 8 mix to channel 1 for the left servo. The results can be seen in this file if you load the aircraft editor and expand the Software Radio section. |
RE: flaperons on G3
Thanks!! I'll give a try...
| All times are GMT -8. The time now is 08:30 AM. |
