Set up for 3D
How do you set up an airplane on G2 for practicing hovering, harriers, etc. The 232 or extra 330 for instance.
Thanks for any help on this gents. |
Set up for 3D
Go to aero3d.net and download some,,,, many great ones there
Set up for 3D
Ive got the cap 232 2X. but it seems a little too easy to do the 3D stuff. Any other aircraft you can recommend??
aero3d.net
Yes,,,,
go to aero3d.net and download 40% cap modified for 3D from Buddy Hale This is the best Cap of them,,,,,,, This is the plane i have been practisin all 3D manuevers,,, and one more thing,,, download also recordings from Buddy Hale He is the best G2 flyer around,,, and learn from him ( I did ) Birgir ,,, ( Big-E ) |
Set up for 3D
Has anyone used these schemes on the older (non G2) version?
RE: VERSIONS WORKING ON OLDER RF
Hello FLUG,
I dont think the down loads will work on the older versions of RealFlight. NEDYOB PS. HI BIG E, Finally got my T/rolls down :) |
Set up for 3D
Do you mean I gotta spend money again?? Oh well. Thanks
RE: DOWN LOADS
Hello FLUG
I think vol. 1 & 2 will work with the older RealFlight. But down loading off the net,Im not shure. NEDYOB |
Set up for 3D
Well, I'd like to try some of this 3D stuff but my Stock add on planes aren't set up right.
I have the (Old)realflight sim with the Add-on that included the red and white Extra 330 3D plane, Harrier...etc..etc. The Extra has the power but that nose really wants to drop off one way or the other. Other planes include the Cap and the Edge 540. I'll see if I can get some of those files open...the ones I downloaded at that site. Maybe I'll be able to get something out of them that will help...ie set ups, CG, control surface deflection etc. I'm pretty sure about having the skill but I don't have the machine set up right. If what I currently have represents a 3D flyable plane...well, it'll end up in the ground about 80% of the time. So, what makes those planes able to hang? I figure that if a guy can fly coordinated multipoint rolls at 10 feet off the ground he should be able to hang the plane on its prop in 3D. Where can I find some hints on how to get set up? Thanks to anyone who can provide links...hints etc. John |
A GOOD EXTRA FILE TO TRY!!
Hi FLUG,
Go to AERO3D.NET and down load the Buddy Hale 40% Extra or the Cap 2X Both of these are good 3D plane scemes. NEDYOB |
Set up for 3D
I've downloaded the 2X cap from aero3d.net....do large scale planes really 3D that easily? I found I could hover on the first flight with that plane having never done it before. Things were a bit twitchy with the big throws and no expo so landings are interesting though...
Set up for 3D
The stock cap 232 is a great plane to try to learn to TR with....its hard...but if you can make it TR...it will be alot easier with your models...I downloaded some of those from aero3d and they are great fliers, but hover and TR to easy....try that stock cap and just stay with it...its hard as hell to get it tostand on its tail some time....but it can really get wound up on you....Gator
Set up for 3D
im new to the flight simulator thing and on the aero3d website you can download any of the planes and fly them on the G2 simulator? Would you be able to do the same with the aerofly pro? Im still debating on which simulator to get the AFP or the G2
Thanks, Santi |
Set up for 3D
Flug,if you go to the realflite web page you can download a cap232torque roller.[orange white black] this plane doesit.you can even adjust how fast it will t/r if you edit the engine,so can start out hovering and add t/r and speed of it as you progress.your game connects you directly to the site.you can get the cap and a corsair.
Set up for 3D
Thanks...I got them.
| All times are GMT -8. The time now is 12:32 PM. |
