G2 Controller Problem
Hi all!
I just received a cord that allows me to plug my 9C into the game port on my computer for use in sims. In FMS I was able to re-map all of the channels in the sim to the appropriate stick/switch and fly. In G2, in the "Advanced" section of the contol options panel, there is a selector that you can use to change the channel assignments, but it is greyed out, I cannot make any changes. The controller inputs are getting through because I can see that the the throttle and the ailerons are swapped etc, but I cannot get things straightened out! Any ideas? |
In the controller calibration menu, at the top, look for:
Stick Mapping: [choices] - select "Custom" That will allow you to modify the stick mappings. Good luck! Chris Good |
| All times are GMT -8. The time now is 09:55 PM. |
