RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Converting 2T fuel to 4T
Old 06-27-2002 | 11:29 PM
rajul's Avatar
Moderator
My Feedback: (58)
Default Converting 2T fuel to 4T
I use 15% Nitro fuel for all my 2 stroke engines and recently I bought a 4 stroke engine. Question is can I use my 2 stroke fuel for my 4 stroke engine ? If it is not advisable, can I modify my 2 stroke fuel e.g. adding certain % of lubricant. Thanks........
Old 06-28-2002 | 01:44 AM
krs
Default Fuel
I use 15% all synthetic oil in 2 and 4 strokes engines with no problem. I have just recently started using Wildcat #109. This is a 2-4 stroke fuel with 15% nitro and 18% oil. Has a very nice smell also.
Kevin
Old 06-28-2002 | 11:44 AM
What exactly are you using now?
Fuelman
Old 06-28-2002 | 12:03 PM
rajul's Avatar
Moderator
My Feedback: (58)
Hi Fuelman........I am using SIG 15% Nitro, 20% lub (1/2 castor, 1/2 synthetic).
Old 07-02-2002 | 03:44 PM
Rajul,
Using that fuel will not hurt anything in the 4-strokes. You may over time experience an excessive amount of burnt castor buildup on the valves and some gumming of the ring land with a high castor content. The bottom line is that the fuel you're using does have enough lubrication and none needs to be added for most any 4-stroke on the market today.
If you have the availability in your area, an all synthetic fuel or a fuel with the majority (80% or 90%) synthetic will best suit 4-strokes as long as it has enough total oil in it to satisfy the engine manufacturers oil recomendations of your 4-stroke.
A little bit of castor in a 4-stroke fuel will help with keeping rust away without gumming anything up.
Fuelman
