RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Adjust for reduced Nitro
Old 07-26-2002 | 12:20 PM
Default Adjust for reduced Nitro
If you have been using 20% nitro and drop down to 15% nitro, will the carb need to be adjusted leaner for the reduced nitro?
Thanks.
Old 07-26-2002 | 01:52 PM
The short answer is yes....the less nitro you use the more economical the engine is so the needle has to be wound in a little. Just tune the engine the way you normally do...peak it then richen a little. The idle may need a small adjustment too.
