RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
making fuel
Old 09-06-2004 | 11:41 AM
Default RE: making fuel
Ed, Ross,
Could you tell me where can I get the ingredients
to mix my own fuel in Toronto/Ont. area?
JP
Old 09-07-2004 | 06:53 AM
JP, This could be an adventure for you.
If you are intending to buy small quantities it is a bit of a chore finding suppliers. Alcohol can be purchased in hardware stores. Look for 99% pure Methyl Hydrate. Synthetic oil such as Klotz can be purchased at Motor cycle stores. Decent hobby stores sell Sig castor oil. Nitro is a problem. I usually buy a gallon from the Klotz booth at the Toledo show.
There used to be a store in Markham called the "Winners Circle" I do not know if it still exists. You will have to dig around and find stores that cater to the performance motor cycle/Go kart crowd.
That is the best I can offer.
Ed S
Old 09-07-2004 | 06:41 PM
Ross Kean's Avatar
I agree with the above. Nitro may be available from speed shops or racetracks - methanol too. There are a variety of sources for oil but it can be surprisingly expensive. One solution for nitromethane, if you are making low nitro fuel such as 5% or less is to buy a gallon of 40% fuel from your distributor. By mixing it with your blend, you can use it to make 8 gallons of low nitro (5%) hooch which is perfectly acceptable for most 2-stroke sport flying. For low nitro mixes, this is likely cheaper than sourcing the nitro separately.
Ross
Old 09-07-2004 | 10:12 PM
Ed, Ross,
Thanks for the information
I might try to look around to make fuel for my own
JP
Old 10-28-2004 | 03:31 PM
Everything you need to know about mixing percentages without any arithmetic.
http://www.rcuniverse.com/forum/Home...2062693/tm.htm
Old 11-28-2004 | 02:07 AM
  #31
PhilNZ's Avatar
Hi,
Lets take the quess work out of this ..
This is a fuel mix calculator in US and metric runs on a WINDOZE PC
If you use this and also use Acetone add this as EDL % 3 % for 2 strokes 5% for 4 strokes
http://www.birdgagesoft.com
winheli is the program, its better than all the guess work
Phil
Old 11-28-2004 | 02:11 AM
  #32
PhilNZ's Avatar
Hi
a correction to the WINHELI site
http://www.birdcagesoft.com
sorry
Phillip
