Gasoline & Nitromethane compatibility
My Feedback: (23)
Has anyone tried adding nitromethane to gasoline? Some of my smaller gassers could use a slight power boost, so I was wondering if nitro might do the trick. I'm thinking may be 5-10% by volume.
I have no idea if nitro is even soluble in gasoline, or if nitro combustion byproduct(s) might be detrimental to gasser internals.
why not just use a valve with NOS (nitrous oxide) connected to it . Don't forget the AMA guidelines while you are at it......
