x-cellerator fuel usage
i was woundering if the X-Cellerator uses up a lot of fuel.....how long willl it last on a tank of gas?[sm=confused.gif][sm=drowning.gif]
CA
You have a car, 18 engine? I get about 8-10 minutes off my ofna with a .28 .Fuel will last for months as long as it has been sealed from moisture, if its been open get rid of it.
so if i got a gallon and open but only use a little all the rest will go to waste if not used soon?
do you havve to mix fuel like this ([link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNE12&P=ML]Trinity Monster Horsepower 20% Quart [/link]) with anything before you put it in your car?
If you keep the lid on it will last a long time, i've used fuel a few years old and not noticed any difference.
Somebody worked out the rate at which methanol absorbs moisture, and even if you leave the cap off for months it's still an insignificant amount.
