RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
close thread
Old 02-10-2003 | 01:31 PM
Default close thread
close
Old 02-11-2003 | 02:30 AM
airega1's Avatar
My Feedback: (204)
Default ST 3000
If it has a C.H. ign. system it makes all the difference in the world, This is probably a gasoline engine, why else would you need an ign. system
Old 02-12-2003 | 05:29 AM
h82crash's Avatar
Uh, the carb will determine what fuel to use. A flyer at my club has ignition on all of his engines and they're glow. He gets idle rpm's to something like 1000. If it doesn't have a Walbro type carb then it is probably glow. Freebelle, after it is broken in you can run reduced oil percentages. I mix 5% nitro fuel to methanol 2:1. That yeilds approximately 12% oil content and somewhere around 3% nitro. ST's run well on little to no nitro. Mine turns a Zinger 18-10 at about 8000 with a Perry pump and an OS 7D carb. Good thrust!
Old 02-12-2003 | 01:33 PM
Thanks for the input. The engine has the stock carb on it and the CH ignition was done by CH. Looking forward to flying this thing.
