RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
mixing fuels
Old 04-24-2008 | 08:52 PM
MetallicaJunkie's Avatar
Default mixing fuels
I have 4 gallons of FAI fuel that i special ordered for a particular engine that i never used..... would it be safe to mix a 1:1 ratio of fai fuel with 10 nitro to get 5% nitro fuel?
Old 04-25-2008 | 12:16 AM
Default RE: mixing fuels
As Gary Cooper would have said......"Yup"
Regards
JC (Smithville, TX)
Old 04-25-2008 | 12:34 AM
Great, i just saved some money
Old 04-25-2008 | 07:33 AM
MetallicaJunkie,
I should have said: "Yup....assuming both the FAI fuel and the 10% fuel are good commercial grade fuels."
The 1:1 mix ratio will yield a 5% nitro blended fuel.
FAI fuel is 20% castor.
Your 10% fuel should be at least 18% oil (castor or synthetic oil blend).
When you mix your fuels you should limit the liquid exposure to air as much as possible. Avoid air exposure under humid conditions.
Regards
JC
Old 04-25-2008 | 08:54 AM
Check out this website for the fuel mixing formula.
http://www.nitrorc.com/
scroll down to Custom Fuel Blending Workshop and go from there.
Old 04-25-2008 | 10:46 AM
thanks for the info, ill call some race shops and see what i can find out
Old 04-25-2008 | 11:04 AM
ORIGINAL: Prairie Mike
great website, thanks
Old 04-25-2008 | 11:33 AM
he local shop sells methanol for 6 bux a gallon.... and the lady i spoke says she is not sure if they sell nitro....hopefully they do now all i need to do is find a good oil additive
Old 04-25-2008 | 07:39 PM
Iflyglow's Avatar
My Feedback: (79)
I am lucky then, it is around 3.00 a gallon in my area (Sprint Car and Late Model stock car racing). They have it at the pump at the local race shop down the street.
Old 04-26-2008 | 08:57 AM
damn, u are luck, i guess since they are the only supplier in about a 3hr radius has to do with why its higher here....
