2% more castor
![](/forum/images/badges/premium_member.png)
NC
I want to up the 18% to 20% oil content in 1 gallon of fuel for break-in. Anyone got a quick recipe on the OZ needed to get to 20%.
Thanks in advance Andy
TX
Close enough. 2 to 3 ounces will do the job for you. More will not hurt anything, neither will a little less. The fact that you are adding Castor is the key, it is the magic stuff that works.
Cheers,
Chip
Cheers,
Chip
MB, CANADA
just remember, that if you add only oil, the % of nitro and methanol go down slightly. In your case its likely not enough to be noticable.
ORIGINAL: andrew66
MB, CANADA
true, the ratio of methanol/nitro will not change, but overall ratios will be different. In this case wont affect too much, but if someone was to add more of one ingrediant than a few Mls it could affect the way the engine runs. The fuel will always be metered by total volume.
NC
Thanks again guys. I added 3 oz and fired the beast up. It went beautifuly... she screamed rich at 16,000 rpm. It brought the neighborhood out wondering whats that sound. I'm new to neighborhood.
NC
ORIGINAL: downunder
OK, I have to ask
. What kind of engine are you running in at 16,000??
OK, I have to ask
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
![](http://img.photobucket.com/albums/v629/asmithnc2004/Children184.jpg)
NC
WOW.... I guess you all like what I've bought or machined for myself. Looks like I'll will be busy packing and shipping. Now, before I finish my girls play / swing set. Would would like it......local pick up only![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
![](http://img.photobucket.com/albums/v629/asmithnc2004/for%20show/000_0028.jpg)
![](http://img.photobucket.com/albums/v629/asmithnc2004/for%20show/000_0029.jpg)
The Jett motor will have plenty of power for your new motor mount
The swingset pic must have been just after the test fire of your new motor. The kids all run off. [&:]
Heres a good fuel mixture calculator for adding oil to premix...
http://www.nitrorc.com/default2.asp?...orc.com/fuelws
Good luck with your new motor, very nice!
