what synthetic oils are out their?
what synthetic oils are out their, how much are they, and where could i order some?
im hopeing for stuff in the 25 buck per gallon range im not sure if they make anything that cheap i know there is klotz but its expensive im planning on mixing this 50-50 with castor so if its not the best oil i dont really care, also if their is something cheap that you have to buy in bulk, like 5 gallons for 100 bucks, im fine with that as well. out of random curisoty i mixed valovoline 5w40 synthetic motor into some methanol and it mixed just fine and has stayed in solution for more than a month, i dont know if i could run my engines with that stuff mixed 50-50 with castor.....is it worth a shot?? i have a few old bushing engines i could try it on. its cheap....like 20 bucks a gallon....who knows if it will carbon like crazy though. |
RE: what synthetic oils are out their?
ORIGINAL: jimmyjames213 what synthetic oils are out their, how much are they, and where could i order some? im hopeing for stuff in the 25 buck per gallon range im not sure if they make anything that cheap i know there is klotz but its expensive im planning on mixing this 50-50 with castor so if its not the best oil i dont really care, also if their is something cheap that you have to buy in bulk, like 5 gallons for 100 bucks, im fine with that as well. out of random curisoty i mixed valovoline 5w40 synthetic motor into some methanol and it mixed just fine and has stayed in solution for more than a month, i dont know if i could run my engines with that stuff mixed 50-50 with castor.....is it worth a shot?? i have a few old bushing engines i could try it on. its cheap....like 20 bucks a gallon....who knows if it will carbon like crazy though. Why not just run all castor? Its $23 a gallon from SIG. You might even find it cheaper elsewhere. It does make a bit more of a mess, but engine longevity is key here. Model engines started running on all castor oil. Doesnt hurt a thing! Just my readily available $.02 |
ORIGINAL: 1QwkSport2.5r ORIGINAL: jimmyjames213 what synthetic oils are out their, how much are they, and where could i order some? im hopeing for stuff in the 25 buck per gallon range im not sure if they make anything that cheap i know there is klotz but its expensive im planning on mixing this 50-50 with castor so if its not the best oil i dont really care, also if their is something cheap that you have to buy in bulk, like 5 gallons for 100 bucks, im fine with that as well. out of random curisoty i mixed valovoline 5w40 synthetic motor into some methanol and it mixed just fine and has stayed in solution for more than a month, i dont know if i could run my engines with that stuff mixed 50-50 with castor.....is it worth a shot?? i have a few old bushing engines i could try it on. its cheap....like 20 bucks a gallon....who knows if it will carbon like crazy though. Why not just run all castor? Its $23 a gallon from SIG. You might even find it cheaper elsewhere. It does make a bit more of a mess, but engine longevity is key here. Model engines started running on all castor oil. Doesnt hurt a thing! Just my readily available $.02 Multiviscosity works and has worked and will continue to work . Some fallicies in teh above post. Sythetics protect just fine. Once an oil has left the exhaust port it no longer needs to protect does it.... The best synthetics out there would be the turbine oils by Fuchs, and Shell (AeroShell). More pricey than the stuff that goes into Klotz but a shed load better. With ABC/N engines its always a good ideal to run a bit of castor (around10-20%, Morgans uses 30% in OMega) due to the lack of an oil ring to create sufficient hydrodynamic lubrication. In ringed engines, pure sythetic is fine. |
ORIGINAL: TimBle ORIGINAL: 1QwkSport2.5r ORIGINAL: jimmyjames213 what synthetic oils are out their, how much are they, and where could i order some? im hopeing for stuff in the 25 buck per gallon range im not sure if they make anything that cheap i know there is klotz but its expensive im planning on mixing this 50-50 with castor so if its not the best oil i dont really care, also if their is something cheap that you have to buy in bulk, like 5 gallons for 100 bucks, im fine with that as well. out of random curisoty i mixed valovoline 5w40 synthetic motor into some methanol and it mixed just fine and has stayed in solution for more than a month, i dont know if i could run my engines with that stuff mixed 50-50 with castor.....is it worth a shot?? i have a few old bushing engines i could try it on. its cheap....like 20 bucks a gallon....who knows if it will carbon like crazy though. Why not just run all castor? Its $23 a gallon from SIG. You might even find it cheaper elsewhere. It does make a bit more of a mess, but engine longevity is key here. Model engines started running on all castor oil. Doesnt hurt a thing! Just my readily available $.02 Multiviscosity works and has worked and will continue to work . Some fallicies in teh above post. Sythetics protect just fine. Once an oil has left the exhaust port it no longer needs to protect does it.... The best synthetics out there would be the turbine oils by Fuchs, and Shell (AeroShell). More pricey than the stuff that goes into Klotz but a shed load better. With ABC/N engines its always a good ideal to run a bit of castor (around10-20%, Morgans uses 30% in OMega) due to the lack of an oil ring to create sufficient hydrodynamic lubrication. In ringed engines, pure sythetic is fine. |
ORIGINAL: TimBle With ABC/N engines its always a good ideal to run a bit of castor (around10-20%, Morgans uses 30% in OMega) due to the lack of an oil ring to create sufficient hydrodynamic lubrication. In ringed engines, pure sythetic is fine. Castor is better though because it likes to "stick" to metal so is much harder to squeeze out from between the working surfaces. This applies not only to the piston/liner but also both rod bushes and plain bearing crankshafts which all use hydrodynamic oil pressure to keep them seperated. |
I mix my own fuel, I use 100% castor, problem is it sticks to everything. I mixed a 50-50 blend (useing a 20/20 wildcat fuel) just to see if it made a dfference in castors "stickyness" and the oil was much easier to wipe offthe plane and didn't gum up my engines as bad. The only reason I'm really using symtjetics is to make the castor less sticky...i agree that castors the best out their for the price....
ORIGINAL: downunder ORIGINAL: TimBle With ABC/N engines its always a good ideal to run a bit of castor (around10-20%, Morgans uses 30% in OMega) due to the lack of an oil ring to create sufficient hydrodynamic lubrication. In ringed engines, pure sythetic is fine. Castor is better though because it likes to "stick" to metal so is much harder to squeeze out from between the working surfaces. This applies not only to the piston/liner but also both rod bushes and plain bearing crankshafts which all use hydrodynamic oil pressure to keep them seperated. all lubricants are polar. is just the degree of polarity that is altered through the additition of polar anti wear addtives. Synthetics has more than enough polarity to do the job well in areas where the hydrodynamic pressure is low. ringed engines are able to retain a greater volume of oil for the hydrodynamic effect. Castor simply provides viscous drag. |
