RCU Forums
-   RC Fuels (https://www.rcuniverse.com/forum/rc-fuels-161/)
-   -   acetone (https://www.rcuniverse.com/forum/rc-fuels-161/352327-acetone.html)
brogo 11-06-2002 03:32 AM
acetone
Hi from downunder.!!!
Someone told me to mix 2.5% acetone to your fuel to help
keep the engine clean and stop oil deposits etc.
I am running a Super Tigre S2000. and would or could this damage the engine?.Also what is the best engine/oil ratio for the Super Tigre's.?.
Regards & Thanks
DerFly 11-06-2002 09:56 AM
acetone
If you use Shell A for mixing, it already has 3% acetone in it. This is generally accepted to be a good thing, at least amongst us Aussies. Search this forum for "acetone" for more info.
As for Tigre Juice, I'm sure someone else will set you staight on this...........
downunder-RCU 11-06-2002 01:02 PM
Re: acetone
Hey, watch it...I'm downunder :D
Sport_Pilot 11-06-2002 06:32 PM
acetone
Doubt acetone will make it run cleaner. Since it has less oxygen than methanol it would probably be slightly worse about leaving carbon deposits.
rcflier_gi 11-06-2002 07:00 PM
acetone
I think the main reason for adding acetone is that it makes tuning the engine easier. It sort of widens the sweet spot when adjusting the needle. I don't think it will clean the engine.
