Ratio ???
What is the correct way to mix my fuel ratio? The local shop owner says its a ratio of oil, and nitro to the meth. Example (100 oz. meth, 15 oz. nitro, 18 oz oil) for a 15%mix with 18% oil.
I thought it was a percentage of the total content. Example (67oz. meth, 15 oz nitro, 18 oz. oil ). For the same blend. Please let me know what you think Dave |
Ratio ???
You are correct with your method. I have a neat mixing chart for excel if you want it. Let me know and I can email it to you.
Ratio ???
1 Attachment(s)
I've attached the excel mix chart in a zip file. If anyone can't unzip let me know and I can email it direct.
Ratio ???
If you look closely at the arithmetic of the example you quoted you will see its flaw. Your example would yield a total of 133 oz fluid. 15 oz of this would be Nitro. 15 oz in 133oz is not 15%.
Ed S |
Ratio's
look at www.klotzlube.com and then look at their support, they have a mixing chart.
Ratio ???
Thanks 3point, the chart will confurm my way to the LHSO.
Dave |
| All times are GMT -8. The time now is 04:46 AM. |
