Rack and Pinion System
RE: Rack and Pinion System
Steering systems on RC cars don't tend to be rack & pinion-type. You may have more luck with robotics stores:
http://www.technobotsonline.com/gear...ion-gears.html
What are you planning to use that kind of system for?
Ever thought of a linear actuator? Pre-built and will do the job you are asking it to...
http://www.firgelliauto.com/
The mini ones should fit in a fuselage quite well:
http://www.firgelliauto.com/default.php?cPath=110
