RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Revo XL builds
Old 10-31-2014, 09:43 PM
twissted
twissted's Avatar
I picked this up for 12.00 shipped from ebay.
I will work it over to fit when I get it.
Old 11-01-2014, 12:24 AM
twissted
twissted's Avatar
The one thing I like about wings on rc is it's a handle when you need to carry it. So when I installed the wing on this build that wasn't possible. So I changed it so that it not only looks better but it's easy to grab on to. I used 1/8 buggy front arms to mount as bracket for the wing to mount to.
Old 11-01-2014, 07:51 AM
twissted
twissted's Avatar
Does that have a HEMI in it?
I will get it installed to the cage so that it lifts when I pull the 2 body pins. I will finish the cage that I cut out and also build a cool air ram also.
Old 11-01-2014, 11:15 AM
twissted
twissted's Avatar
https://www.youtube.com/watch?v=NRQbGInWBQA
Old 11-01-2014, 12:34 PM
twissted
twissted's Avatar
https://www.youtube.com/watch?v=jwIvlUODoV0
Old 11-01-2014, 12:35 PM
  #31
twissted
twissted's Avatar
I got the losi 5T lights in the bumper.
Old 11-02-2014, 12:40 PM
  #32
twissted
twissted's Avatar
With the added scale motor I'm hoping I can still be under 19 pounds. I order some one piece lipo trays. I think that I'm not adding a carbon pan to this build to keep weight down. If it gets to messy inside I add some light weight plastic.
Old 11-02-2014, 12:43 PM
  #33
twissted
twissted's Avatar
my drivers are looking pale! time to paint.
Old 11-02-2014, 12:45 PM
  #34
twissted
twissted's Avatar
Well my Goal was to do this build loaded a19 pounds That is 10 pounds lighter than the orignal Losi Desert Buggy XL! I made it It is just under with the 1/5 bead locks and a pair of 2s 9400 lipos. I'm stoked!
Old 11-03-2014, 12:33 PM
  #35
twissted
twissted's Avatar
https://www.youtube.com/watch?v=Ni7zs2nfIjc
Old 11-03-2014, 03:56 PM
  #36
twissted
twissted's Avatar
https://www.youtube.com/watch?v=swpLDMoj2Vo
Old 11-04-2014, 02:09 AM
  #37
Mudgy
Mudgy's Avatar
Looking good mate.... I had forgotten your dog is so full of beans!!!
Old 11-04-2014, 10:30 AM
  #38
twissted
twissted's Avatar
thx!
So last night I ran it when the sun went down so no video. I did run it fairly hard. put some scratches on the lid and the scale Hemi came unglued, so I used E6000 cement to put it back together. It should hold up know. I also added the cooling lines to it and the air intake snorkel. I need to come up with a aier intake that looks good next and then a radiator and fans to get the look need for scale.
Old 11-04-2014, 12:00 PM
  #39
twissted
twissted's Avatar
Light Bar is in the works!
Old 11-04-2014, 01:17 PM
  #40
twissted
twissted's Avatar
Not bad for scap parts. I knew this light bar would come in handy. I had these for quite a while now. I will find so super bright Led's to put in place of the weak ones that are in it.
Old 11-05-2014, 04:30 PM
  #41
twissted
twissted's Avatar
I need better brushes. My paining skills aren't good as it is. brushes would help.
I nailed the skin tone. To bad the rest in't so good. If I had to get the color right to repaint, I don't think I could get lucky twice.
Old 11-05-2014, 10:00 PM
  #42
twissted
twissted's Avatar
https://www.youtube.com/watch?v=FSYZVvCDRBw
Old 11-08-2014, 04:05 PM
  #43
twissted
twissted's Avatar
My lipo trays are in. I had to cut the trays to get the 9400 SMC's to fit.
Old 11-09-2014, 12:15 AM
  #44
twissted
twissted's Avatar
I have 5 of these on the way to get my light bar working.
There the brights ones I can find!
5 pcs A Pack of 10MM BRIGHTEST WIDER VIEWING ANGLE WHITE POWER LED 1W WITH 390,000MCD FOR CAR MOTO BIKE BOAT LIGHT DIY
FEATURES:
New !
In excellent condition
Long lasting (over 100000hours)
Low Power Consumption
I.C. Compatible
Intensely Bright
SPECIFICATIONS:
Source Material:InGaN !
Emitting Colour:10MM POWER WHITE 1W LED
LENS Type:Water clear
Color Temperature: --
Luminous Intensity-MCD: Typ: 390,000 mcd
Reverse Voltage:5.0 V
DC Forward Voltage: Typical:
DC Forward Current:300mA
Viewing Angle:40 degree
Lead Soldering Temp:260°C for 5 seconds
Absolute Maximum Rating (Ta = 250C)
Old 11-09-2014, 10:48 AM
  #45
C.lyra
C.lyra's Avatar
Like your projekt, Where did you buy the upgraded diffs? And is it the same as a savage?
Old 11-09-2014, 09:52 PM
  #46
twissted
twissted's Avatar
No I got them off of ebay and there Hot racing products
Old 11-09-2014, 09:53 PM
  #47
twissted
twissted's Avatar
Well I tried my trans. I don't like it for a few reasons. 1) no slipper clucth 2) motor over heats to fast. 3) to noisy.
So I'm going to modify the drivetrain and try a savage trans or the summit trans.
I'm leaning on the Summit trans because of it's compact size. I like the 2 speed also.
Old 11-09-2014, 10:48 PM
  #48
twissted
twissted's Avatar
So can any one guess what is different about this Summit trans install than any other install of this kind?
(Hint) look at the lipos and steerig servo.
Old 11-10-2014, 04:12 PM
  #49
twissted
twissted's Avatar
Old 11-10-2014, 05:18 PM
  #50
twissted
twissted's Avatar
I ended up using the Revo transmission and will save the Summit trans for the 18.5" build that will have the Yeti XL body.
