Bought a HPI Baja 5B and have questions - Please help.
Hi Guys,
I am not new to RC but new to Large Scale Petrol vehicles. All this time I only played with Electric 1:10 or 1:8 scales. The sound of Nitro and Gasoline vehicles always fascinates me but I was hesitant because of the troubles of tuning and taking care as I don't know anything about such vehicles.
Finally, I decided to go for it and instead of going for Nitro I went for Gasoline and since I don't have long pockets so I bought a used HPI Baja 5B from a reputable Hobby Shop dealer whom I know from a long time and have complete trust that he will sell me the original Baja and not the clone.
The car has some upgrades installed by the previous owner like shock covers, few aluminum parts inside. But most importantly as per the shop keeper there is a 29 cc head piston installed and also a tuned pipe. Like I said I am new to these cars so I don't know what is the significance of these parts. Here are a couple of questions:
1) The shop keeper says that these upgrades make my Baja 5B 29 cc and not 23 cc. Is he correct? Please not the engine is stock 23 cc and its just the head piston which is 29 cc.
2) Can you please identify this installed tuned pipe and please tell me what this do?
3) My Baja always starts after like three or four tries and never in the first or second try. Is this normal?
4) Now this happens sometimes that after I start the engine it stops automatically after like 2 or 3 minutes and this happens specially when I give throttle a little push only. But when I go like full throttle or middle throttle it stays fine but it stops if I give throttle a tiny push in the beginning. What causes this?
5) I have a temp gun so can you please tell me what is the accepted temperature of engine. Its always hot as hell in this part of the world. So please tell me what is the accepted and alarming engine temp readings?
I have few other questions too but this post is getting too long. I ll ask those questions later. Kindly please reply to my questions.
Here are some other pictures of the car.
Thanks a lot.
Thanks a lot.
1) He might be, but you will never be sure unless you take off the cylinder head and measure the bore/piston diameter inside. I don't remember on the fly what the diameter should be to make it 29 ccm though.
2) Can't identify it, but what it does is amazing things for the engine compared to the stock muffler can that is on the car when new. A great upgrade.
3) This is normal. If the carb has a choke, you start it with this "on", then yank the pull start until you hear it pop and then turn the choke to off-position.
4) Could it be the needle for the idle is set a bit low on your carb that causes this? Also might be the low setting-needle on the carb.
5) Don't know, i always adjust my engine by ear to know they sounds healthy, that also means that they get enough fuel to also be cooled sufficiently.
There's a few different ones.
Google will know more.
I have one that looks suspiciously similar which I put on a chainsaw motor.
It made it sound very angry haha.
Hey mate one of the first upgrades you should do is get a killer bee kill switch it you dont have one already it will save you a lot of hassle from run aways etc , as for temps best to just run it and see i think you will be fine .
