1/10 tire adapter
CO
RE: 1/10 tire adapter
ammdrew what tire adapter did you use? i was thinking about doing this but i did not know how the rims would hold up. have you ran with them on and how did it do?
rims are doing good, you can expect them to eventually break, as they break with the 1/10th scale truck already, but does give you great options of using up those tires.
The adapters are coming through the FG US dealer network.
If there are adapters for those size rims... then I assume aluminum 1/10 rims would also fit... thus being stronger.
Are there aftermarket Alum. rims available for the marders stock tire size?
thanks
thanks
