Fg M Truck. my mods so far
So Iv'e now had my FT for three weeks,and been well happy will it in allServos fitted are all Hi tec 1/4 scale for the steering,metal geared and ball raced for the throttle and rear brakeFutaba 4channel 40 meg receiver powered by a 2000mah 6volt battery pack.
First run was on Tarmac lots of rear wheel spin handled quite well but did seem to power slide when in a bendthen had its first roll over without body shell on and snap went the two front body posts[:@][:@].
First mod was to sleeve these over with some alloy tube much strongeralso found that as I had fitted the FG tuned pipe the rear screws had come out of the plastic rear body frame so I also changed these to 4mm alloy bar with a 3mm thread in each end to fit 4 3mm x 45mm set bolts much stronger.
I have now also changed the shock oil all round to make the ride a bit softer handles much better on and off road,I can drop it from 600mm high and it lands without the chassis hitting the tarmac.
I have also fitted some foam inserts in my tyres.
Banned
RE: Fg M Truck. my mods so far
I was mooching in my local B+Q and they've got some some foam pipe lagging that looks like it could be cut to fit perfectly..........
Can I ask what shock oil you changed to that allows you drop it from that height? [X(]
ORIGINAL: rrover
What oil did you put in?
CK
Hi FGUK I have used a Hydraulic oil,the foam was cut like a long oblong 540mm long,200mm wide,30mm thick .
rrover
rrover
