FG ----MT
FG ----MT
Please can any one tell me the hight of the front body mounts from above the shocker mount to the underside of the body , on the pics there seems to be 2 bits of black plastic with a "R" clip through them Thanks
Steve
Steve
RE: FG ----MT
Thanks but I could do with the actual hight to the cross bar on the body mount down to the top of the shocker mount, the project is a 4X4 MT movimg the shocks to the top wishbone and remaking the top shock mount and body mount. I want to know if what I want to do will fit under the body
Steve
Steve
RE: FG ----MT
From the top suspension bolt to the very top of the upright is 97 mm
The top hole is 90mm
There are 6 holes and the bottom one is 45 mm from the top bolt of the suspension
the plate rests on clips on the second hole down which is 87 mm an dthe body is then level with the top hole for more clips to hold the body on
Hope that helps
kj.
Hope that helps
kj.
RE: FG ----MT
Thanks a lot have been drawing the ally components I need to do a 4X4 conversion, will start machining them next week probably , I only have a grotty old marder to go on, so will try the set up on that before moving it all over to the new longer chassis that will take the new body, excelent Thanks
Steve
Steve
RE: FG ----MT
Belt multi v flat belt I can get it under the engine, if it works I may sell the kits. my homemade CNC mill is a bit slow for production use
But you never know
Steve
But you never know
Steve
