no drive help
no drive help
Hi Guys, hopefully a small problem that you can help me with, iv lost the drive in my MB we were running it in a park (50mm Grass) a lot of the time flat out. then it came to a halt, it revs freely and if you lift back wheels they spin but under load it wont move, gears etc look fine, before i start stripping it down i thought i would ask if you guys have had this prob
Banned
RE: no drive help
Firstly.........
Check the grub screws in the square wheel drivers on each of the back wheels, if one is loose then it won't go far! They are alloy bits that your wheels fit onto.
Was out with my Marder with another person from this Forum, who shall remain namesless, but is Australian a few weeks ago and his Monster Beetle stopped moving, he packed up and went home, only to find it was the wheels squares that had come loose!!!
RE: no drive help
or is the squares have not come lose, have they rounded the bit on the wheel that they fit into?? thats what happened to me. so ill have to get some KPD spiders.
RE: no drive help
My guess is clutch key on main engine shaft
Take your bell housing off then remove the clutch shoes , there should be a little square or half moon key in the shaft. If it is in pcs just replace it.
You can even hand file yourself a new one if it is broke from a small pc of metal you have layin around. ( otherwise you will probably have to order it )
hope it helps
hope it helps
RE: no drive help
Hmm, I dont think so on a Zenoah, its a tapper shaft? As FGUK said, first check the wheel drivers, as this always happens, the little grub screws slowly get pushed back up into the driver, Fit steel ones and that should be a fit and forget item, If its not that (which I think it is) then check all the grub screws in all the drive line, from the big gear (46/48) the little one behind the engine.
Steve
Steve
ME
RE: no drive help
Same thing happened to mine, it was the plastic gear carrier behind the spur gear. Not sure if thats your problem but worth checking.
amitysanimal
amitysanimal
RE: no drive help
Thanks for the advice guys, the grub screws on the square wheel drivers are fine, checked others all ok, i think it might be the diff cos i can turn the diff cog and it wont turn the wheels, could it be iv stripped the diff gearing. my nitro trucks were always stripping the diffs, i hope the mb isnt gonna be the same.
RE: no drive help
You were nearly right Amity. the plastic spur gear has gone rounded, i was told that the plastic gear carrier would wear when i brought the MB and Kevs racing bits gave me the alloy upgrade when i brought the MB from him, i just wasnt expecting expecting it to wear on the shaft.. thats a shame i so looking forward to spending more money on these trucks this week..a week off... oh that could a bad omen... could be double nxt wk.. thanks for your help guys
