Fitting a ZG22/G2D with G260/4
I'm going to replace the faulty ZG22/G2D engine in my Marder a bit later on with a new G260/4, but I want to know will the parts from the complete whole assembly from my existing engine fit into the new one? And will the 260/4 fit the Marder chassis mount holes?
Engine mount
Clutch & clutch bell
Pinion & Spur + brake assembly
Gearing that drives diff.
Basically I just want to remove engine, replace salvable parts from my engine and fit to new engine, fit whole assembly to car- setup/run in..ideally no further other (expensive) parts to purchase. See attached pic for engine
Engine mount
RE: Fitting a ZG22/G2D with G260/4
You might need a different engine mount bracket part no 6134/1. I thought I needed one but for my ZG22 it was the wrong size. In the end I needed another bracket (forgot part no) so I've got a new one going begging. PM me if you want it.
