Marder Crash
Marder Crash
Crashed my marder last night after just putting it back together from hitting a tree last month. I even had my glasses on. Open field and i can find something to crash into. this time it was a 4 inch pipe. i think its going to be awhile before it gets fixed . Whats the best way to try and pound the chassis back down? Just pound on it or try and heat it up first?
shymot
shymot
RE: Marder Crash
Yeesh, pretty bad. Damaged the servos? I wouldn't trust the throttle/brake servo now. Damaged the a frames, or just went dead on with chassis? []
Bad crash myself also- pipe/header/throttle-brake servo
RE: Marder Crash
[shameless plug]
I'm selling a Marder chassis- also have front & rear bulkheads, I guess yours have sheared off threads.
Bad luck though.
Bad luck though.
PA
RE: Marder Crash
As long as you dont see any cracking in the aluminum you should be able to take the chassis plate, lay it on a table with a block of wood over it and beat it back in shape with a hammer. Worse thing is you have to take everything apart just to get to that point.
That sucks!
That sucks!
RE: Marder Crash
Do NOT heat it up, you will loose all strength in the material.
Besides the bending the plate it twisted also from what I saw on your pictures, that is worse. []
As it influences your car going left or right. However I saw similair plates and after bending them back they still are ok to continue driving with so do not give up yet!
Go and use the aggressive adrenalin you still have in ya for bending it back, you will need it.
Good luck and maybe Australis could give you some advice as he encountered the same prob a few weeks ago, there was a complete thread how he re-worked his bottom plate back again.
RE: Marder Crash
I hit a curb at about 15 - 20 mph head on with my Firehammer. I did not notice any chassis or suspension
damage. All of my fuel leaked out of the car. The gas tank had a nasty stress fracture centered on where
the "back" screw of the tank mounts to the chassis plate.
I replaced the tank and am up and running again.
Has anyone replaced a broken tank and fixed the setup of the tank to guard against this happening again?
Ken
Ken
UT
RE: Marder Crash
I do aircraft sheet metal...you got one hell of a bend there I've bent my xtm's frame after hitting a pole but not as bad..I just worked it back into place over the edge of a table...don't ever heat aluminium to rebend it, you'll run it for sure...be sure to look for cracks also it seemed to be t3 on my xtm but I've read some companies are using T6 on them and at .250 T6 you maybe need a few neighbors to help flatten that back down.
RE: Marder Crash
Hi i have a marder and hit a curb pretty hard as my bat lead worked loose and at around half throttle hurtled into a cub not even my spectrum failsafe could save that one , i just wondered if you guys knew at what angle the kick up is at the front of the chassis?
cheers j.
cheers j.
RE: Marder Crash
cool i think i read that aswell in another post but wasn't sure if it was solely the marder chassis thanks anyway i think your right though.
j.
j.
RE: Marder Crash
During a recent browsing session I found this Reinforcement for the Marder at http://www.alu-tec.de
They also make some COOL 5mm F40 Alu alloy Marder frames.
Those 2 together should add up to a virtually unbendable front
And if it bends, It will do it elsewhere, and AUCH!! What a Crash
RE: Marder Crash
just got that chassis last month from alu-tec,nice quality custom items for the price,bought a few things in the past from him - cheap postage also to the uk
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=150073921252
RE: Marder Crash
ORIGINAL: JASETHEHELIACE
HI LOOKS GOOD CAN YOU DO ME A QUICK FAVOUR AND SATISFY MY CURIOSITY IS THE ANGLE OF THE KICK UP 10 DEGREES?
in the past and i've had the same proble till i made my own .. the kick up angle i was told was at 11 degree's ..
good luck m8
