STEERING ?
MI
STEERING ?
I burnt up my 5745 Hitec steering servo(big suprise)and ended up putting 2 tower hobbies giant scale servos in its place. The problem I'm having now is I don't have full range of steering in either direction. Its the same in each direction . It stops turning about a 1/4 in before the stops hits. The dual rate is at full turn and the end points are full on. The servos were cheap but they have alot of power so I thought I would give them a shot. Any ideas? Is there some adjustment I'm not figuring out to get full steering? Do some servos have a shorter range of motion? Both links from the servo horns to the servo saver are the same length.
