Servo Saver
Servo Saver
I had to replace the bolt shaft that goes through the centre of the two plastic pits on the servo saver. I have taken it apart and i can't remember how it all goes back together with the two washers (one big one and a small one) and where the spring clamp goes. Thanks. Darren
RE: Servo Saver
Try the washer with the larger hole on the chassis then the servo saver then the small hole washer then the Eclip
going from memory here????
