Carb Tuning with Samba Pipe
Hi all
I've just fitted a Samba pipe to my Marder Race (Zenoah 26cc) and was wondering whether the Carb settings need to be adjusted.
Cheers
Gary
Cheers
Gary
RE: Carb Tuning with Samba Pipe
not necessarily, run it around for a while and if the engine doesn't sound right. screw the jets screws in. Then turn them back out. Turn the L screw out 1.5 turns and the H screw 1.25 n work from there turning the screw 1/16 of a turn at a time. if yu ned any help on what direction to turn the screws reply on this post n ill be able to help you out. i only know what im on about when it comes to carb settings because i had to change mine when i installed my FG Tuned Pipe.
Cheers for the advise, will give it a blast on a nearby field and see how I get on. I've started the car and it sound superb conpared to the standard exhasut.
Gary
Gary
