oil to fuel ratio
RE: oil to fuel ratio
XX of petrol (gas) /25 = correct amount of oil. Useful reading. Damn Imperial/Metric differences...even in liquids
http://en.wikipedia.org/wiki/Gallon
WA
I made it 32/1 found info on Ams oil site the fuel is 114 octane not 104.
Thanks for the help.
The metric system is not happining here!
CO
ounces of oil per gallon of fuel
20:1---- 6.40oz oil
25:1---- 5.12 oz
30:1---- 4.26oz
32:1---- 4.00oz
35:1---- 3.66oz
37:1---- 3.46oz
40:1---- 3.20oz
42:1---- 3.04oz
45:1---- 2.84oz
47:1---- 2.72oz
50:1---- 2.56oz
52:1---- 2.46oz
55:1---- 2.33oz
57:1---- 2.25oz
60:1---- 2.13oz
62:1---- 2.06oz
65:1---- 1.97oz
67:1---- 1.91oz
70:1---- 1.83oz
72:1---- 1.78oz
75:1---- 1.71oz
77:1---- 1.66oz
80:1---- 1.60oz
82:1---- 1.56oz
85:1---- 1.51oz
87:1---- 1.47oz
90:1---- 1.42oz
92:1---- 1.39oz
95:1---- 1.35oz
97:1---- 1.32oz
100:1---- 1.28oz
sorry i got carried away,
hope this helps.
20:1---- 6.40oz oil
25:1---- 5.12 oz
30:1---- 4.26oz
32:1---- 4.00oz
35:1---- 3.66oz
37:1---- 3.46oz
40:1---- 3.20oz
42:1---- 3.04oz
45:1---- 2.84oz
47:1---- 2.72oz
50:1---- 2.56oz
52:1---- 2.46oz
55:1---- 2.33oz
57:1---- 2.25oz
60:1---- 2.13oz
62:1---- 2.06oz
65:1---- 1.97oz
67:1---- 1.91oz
70:1---- 1.83oz
72:1---- 1.78oz
75:1---- 1.71oz
77:1---- 1.66oz
80:1---- 1.60oz
82:1---- 1.56oz
85:1---- 1.51oz
87:1---- 1.47oz
90:1---- 1.42oz
92:1---- 1.39oz
95:1---- 1.35oz
97:1---- 1.32oz
100:1---- 1.28oz
hope this helps.
MI
Get a ratio right from a motorcycle shop or hardware store. It has all the ratios and you just fill to the line that is the ratio you want to run and pour it in your gas can.
Hey thanks for the info. I've got the FG BigFoot. I've had many nitro and electrics, but I 've got no experience in the gas/oil mixing. Is there a particular brand of oil you guys use? Something from Home Depot or the Hobby store?
Jeff
Jeff
I personally use a new type of oil called N-Tek, which claims to have 80+ more %age of lubricity that any synthetic. That was recomened to me by the president of the company at 70/1..
Dump the racing fuel on the weeds and run regular 87 to 94 octane (or white gas) all high octane fuel does is over heat your engine and reduce performance
I run Bel-Ray H1R at 40:1. There's another forum thread running about this. Someone there recommended 50:1 for the Bel-Ray. I'm happy so far as I know with the 40:1 (but am barely a novice on 2-cycle engines).
Am I just wasting Bel-Ray oil by running 40:1 or doing damage to my engine? If not, I can afford to continue running 40:1.
Ken
Ken
The worst you can do by using 40/1 as opposed to 50/1 is risk an increase in build up of carbon deposits and produce more smoke but who cares but at 50/1 if the carby is adjusted too lean you run the risk of damaging the engine sooner than if you run 40/1
I run Castrol TTS at 32/1 but the oil is good enough to handle 50/1 but at 32/1 I have more margine of error with the carby tune.
Zenoah recomend 25/1 with a good quality oil.
You can buy a lot of oil for the cost of an engine rebuild.
