6 horse briggs and straton motor HELP ME!!
ok heres the deal i have a old school turfmaster 6 horse tractor the motor is junk so i need to take it out well when i took the deck off i sax the crankshaft and it had a big pully on it and it looks like it is mounted right on the crankshaft permanantly and i need to get it off to put the new motor on also how do u take off the square thing on a briggs 3.5 motor itsd the thing that holds the blade off i dont know how to get either off of the crankshaft HELP ME hoping for replies in 7 hours MAX!! help me please
RE: 6 horse briggs and straton motor HELP ME!!
You used so little punctuation and made such little effort to organize coherent thoughts, I have no bloody clue what you're actually wanting help with... oh, and "u" is not a word. Consider re-writing the question using something approximating english, so people can read it.
(and depending on what you're asking, photos might help)
--Randy
--Randy
PA
Well first off this doesn't sound at all related to giant scale r/c's, but with that said i'm more than willing to help. Like the previous post stated you will probably need to post pictures so we can really give you a hand.
It sounds to me like you are trying to get a pulley and the blade off this lawn tractor? Does the pulley have bolt in the center of it? If so then it is probably removable, but it may be pressed on. Usually in this case you need a special puller that is meant for removing something like that. (after you remove the bolt first of course) You can sometimes get away with heating the center of the pulley with a torch to expand the metal and then carefully pry it off. Sometimes this works, others it doesn't.
The blade on most lawn mowers is held on by a single bolt in the middle of the blade. You remove that bolt, and the blade comes off. If thats not the case then you will need to post pictures.
the blades are off both motors i need to get the pully off the tractor and and the blade mount off the motor u should know what im talking about if you know anything about small engines. HA puncuation muahahahahahahaha, but yeah i use the letter u for a word called YOU. god y do u gotta flame man what the heck? but its the little square thing on the bottom where you bolt the blade to i cant get it off ive tried like everything its on the crankshaft directly mounted to the motor same case for the lawn tractor motor and it is large scale cus im making it rc. it has to be able to be removed or else how could u have put the motor on and take it off not to mention u cant just put a huge pully through a tiny hole lol well write back and no more flaming thatnks ryan
FL
No one was flaming... Just suggesting propper forum mannors, and actually asking that you follow RCU guidelines. As to your question. Every model of tractor is different and they are not all the same. The part you are asking about is more than likely pressed on. The way they are pressed at the factory makes it seem like it is permanent, but it just takes alot of force to remove, or even eassier.... cut it off. Show some pics and then we can all try to give better help.... I am not exactly sure of what you are saying.
oik if i cut it iff then that means i wont have a crankshaft anymore lol its connected to the crankshaft
I think some of those engines over here had a key way shaft whether that one does or not i don't know,but it must come off some how as most of the time the pullys are put on after the engine is fitted.Pictures can tell a thousand words but like you said you don't have a camera so it is sort of hard to help without seeing it.
TX
I have seen the part you are refering too (I think) and some of them had been pressed on and the crank had grooves cut in it along the length of the crank. I can't remember the word for it right now( knurled maybe?) anyway, it was just pressed on. You would need a puller if yours is like this.
Any auto parts store, most large hardware stores, etc.
Check to make sure it doesn't have any set screws or pins.
--Randy
--Randy
it doesnt have any set screws. what is it called tho like is it a 1 size fits all? can a puller put it back on? how much do they cost? You guys are on RCU are great i want to thank everyone for helpin my noob ass out lol.
ORIGINAL: fourwheeler
i got it off yippee lol i used a wedge and a hammer . i put the wedge under the pully where the motor mounts to the chassis and i hammered it in it took about an hour but it cam off and the 3.5 hp lawnmower engine thingy just came off lol right when i started it i reversed the puleysd from the tranny to the motor and it is soooooooooo fast but scarey to be on when someone els is driving it lol considering the seat itns bolted on
