Castrol A747 or Castrol TTS
Hi Guys,
Quick question, which is a better two stroke oil? Castrol A747 or Castrol TTS? Also does anybody recommend anythig?
MI
RE: Castrol A747 or Castrol TTS
I recommend blue marble oil. Go to http://www.envirofuelslp.com to check it out.
Amsoil or Castrol A747. A lot of the European drivers use the 747 oil while Amsoil is the oil of choice for a lot of the 1/4 scale drivers
Thanks guys I will try one of these. I will proably go with the amsoil, or if I can find it here in Arizona I will try the blue marble oil.
i'm an old Moto-X & shifter Kart racer for many years & i used A747 with no problems in pretty much all my engines all the time
40:1 with 747 & you're good to go
we used this in some very highly tuned go-peds a couple of years ago & found it gave excellent lubrication and clean running
