Venom smart temp settings
My Feedback: (8)
NE
I have a smart temp and pitched the instructions. When the system gliches it applies the throttle not the brake. This is not good. I can not seem to get it to reverse. Can any one using one of these things help me out?
FL
RE: Venom smart temp settings
Pay close attention to step 6 in the instruction manual. That will fix you up. I had the same problem so I finally broke out the manual and figured it out. When your setting the percentage make sure your on the screen with the little f next to the numbers. I hope that wasn't to complicated I don't how else to explain.
My Feedback: (8)
NE
Thanks for the help. I have only used the thing for about three tank. The first time I set it up it went fine. I had a new JR XS3 TX and it would always cut out. I swaped it for another JR TX and it worked fine for a while. It then went to where it would apply the gas and not the brake. I followed the instructions but it will not go to the screen I need. The POS is shot. Does not do any thing but go through the screens and causes the servos to glitch. Removed it and all works well. Time to look for a new fail safe. Will not be a Venom that is for sure.
