FG Monster truck questions
I drove the truck for the first time over the weekend and noticed that the front wheels "wag" a lot in a turn. I tured the wheels and noticed a lot of play on the servo it self. Is this just a crappy servo that comes with the car? I bought it pre-built. I drove on grass to run the motor in. I do not know the part names - hope you understand the following. Looking at the left wheel while turning to the left the long bolts on the "ball link" where the steering rod connects to does not touch the "a-arms" but the wag was so bad that it hit the arms and bend these bolts. I did not jump at all. Any advice?
I also noted that if I push the front suspension all the way in the front wheels touches the body. Do I cut the body bigger around the wheels or is something wrong. I bought it pre build.
