mader body
RE: mader body
check his other auctions he has unbreakable rear wings also - the shell is £61 which is normal price in uk not sure what you guys pay in usa - i think for extra £5 he will post world wide.
http://cgi.ebay.co.uk/FG-MARDER-POLY...QQcmdZViewItem
RE: mader body
The Lexan 2mm body from Hobbyteck is the cheapest, and also toughest I believe. You need to do alot of cutting work though. But I guess at least if you find the official FG marder poly body too weak around the roof you can just remove the holes as needed on the thicker lexan body.
PA
RE: mader body
I believe the lexan body is made by FG so you should be able to get it right from http://www.molzermoweryracing.com/
EDIT: Although Krikke has a listing of what i think is an FG part number 6154 it doesn't come up on molzermowery's site when i do a search. You can always call them to find out if they have it though.
763-525-8267
763-525-8267
RE: mader body
the lexan one is after market shell - fg do either the poly carb or the weaker white abs - i agree with mad max and opt for the clear lexan as there very strong and half the price but do require some cutting - the same site also does the mud marder shells that have pods built into the side for 81.euro
mud marder
mud marder
RE: mader body
6154 is the standard poly body- I'm talking about this one- 59 Euros so is much cheaper
http://www.rc-car-online.de/marder_2mm.jpg
6154 is 84 Euros.
6154 is 84 Euros.
ON, CANADA
RE: mader body
I just ordered the Mud Marder body from Hobbyteck. Does anyone have this?? If so how is it? I love the fact it's like a version of the Leopard since I use to have a couple of 1/8 buggies myself. I want a really think body for mine. I have the ABS one now after going through the MT and the MB body. This will be the first one I'll paint since the other 2 were used. Hope it's as hard as they say so it will last big time.
