Marder race suspension arms.
I just wandered if anyone could tell me if the bottom front suspension arms are the same on the marder race as on a standard marder. I know the tops are different but i was thinking of converting mine to a race ,does anyone know which parts i would need for the front? Would the standard wheels still be ok?
Thanks for any help.
RE: Marder race suspension arms.
the marder race front end is dif over standard - the race has turnbuckles on both upper & lower wishbones - standard has ball and socket joints built in.the race "A" bulk head has adjustable block built in to allow travel adjusting on the upper wishbones.standard wheels will fit ok but the marder race comes with with the wider track wheels as used on the leopards.instead of spending £80 on replacing plastic for plastic why not pay that little extra and get elcon alloy front end which is adhustable ect.
