Cable brake question.
RE: Cable brake question.
as long as they are not in constant contact when brake is off should be fine, i find the cable brakes very easy to maintain and adjust
I use a much less advanced "tool". I simply thought that I might adapt the trick when setting the mesh on my smaller scale cars btw. the pinion /spur, and I use the FG plastic parts bag in between the disc and the brake pads.
Seems to work every time.
