Diff Housing Bearings - 15mm ID
Found an alloy diff housing in my box of bits which requires bearing with 15mm ID.
It's from an adjustable diff.
Anyone know which model it's for?
RE: Diff Housing Bearings - 15mm ID
It's the bearing that fits in the axle mount. Thought it'd be easier to trace the bearing if I knew which model the diff came from.
Thanks, just found it in the FG catalogue. Uses smaller bearings with a plastic spacer to save weight. - Part no. 8508 for anyone interested.
